GDL
Transfer Building materials' fill attributes to Sections/Elevations and plan
Durval
If I create the parameter "build_mat", of type Building Material, then write this in the 3D Script:
BUILDING_MATERIAL build_mat
BLOCK A, B, ZZYZX
Then create a section passing trough my object, shouldn't I see the block filled with the same fill that is set for the building material?
All I see is an 'air space' fill, no matter what building material I set to the object.
Also, how could I use this same fill in plan, combined with PROJECT2{*} function?
--- www.dtabach.com.br ---
AC 27/28 BRA – MacBook Pro Apple M2 16GB RAM Mac OS Sonoma
Peter Baksa
This should work. Be sure to turn off Floor Plan and Section > Cut Surfaces > Override Object's Attributes, and use Cut Fill in Section Setings > Model Appearance > Cut Elements > Cut Fill.
Use REQUEST{2} ("Building_Material_info") to get the fill index.
PƩter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
leilei
Hi,I have the same problem. Have you solved it
Lingwisyer
Guru
http://gdl.graphisoft.com/tips-and-tricks/explore-the-project23-command
Pull the Fill of your Building Material then insert it into the gs_fill_type parameter?
Peter Baksa
PƩter Baksa
