2021-08-21 03:32 AM
Solved! Go to Solution.
2021-08-21 04:29 AM
2021-08-21 06:33 AM
2021-08-21 09:43 AM
2021-08-22 01:33 AM
2021-08-22 03:54 AM
2021-08-22 06:42 AM
insideru wrote:Yes I agree with you.
but i prefer to stick to layers to order elements (interior/exterior walls, slabs, etc)
2021-11-13 01:22 AM
Hi again,
Last time I thought that I did it or maybe now I am doing something wrong. The problem that I am having now is how to apply 'Graphic Override' only to walls, slabs and other stuff that are 'As built to sanction'. Because when I am applying the Graphic override, all stuff are changing colors not only walls that are 'As built to sanction'.
In other words I want to select 'Graphic Override' for only 'As built to sanction' walls and only those walls turn into blue and not all walls.
2021-11-14 04:48 PM
You have to set the criteria to filter for the elements you want to affect.
2021-11-15 12:28 AM
Hi Barry Kelly thanks for your reply. Yes I changed Element type to Wall and it's OK. But how can I apply only to 1 or 2 walls instead of all walls? Because like this all walls are changing colour.
