Document & Visualize forum
Exporting a PDF creates empty files
jamesMorris
Exporting a PDF file creates a second empty file. Just one user has that problem.
Does anybody else have the same problem?
It looks like you are saving to a cloud-share folder.
I wouldn't save directly to that folder as it may start to share while you are still creating the file.
I find it better to work in a non-shared folder and then when you do want to share, copy the file over.
Versions 6.5 to 25
Versions 6.5 to 25
jamesMorris
It is an SMB folder that is accessed with a VPN, so you are probably right.
Cheers!
Labels
