CRT
is there an add on to export as a .stp file
is there an add on so i can export as a .stp file
Thanks!
furtonb
Not that I'm aware of. You could try using IfcConvert for exported IFC files:
https://docs.ifcopenshell.org/ifcconvert.html
If you have access to Rhino, use it as an intermediary step to clean up geometry then export as STEP.
(For the most convenience you should use an IFC supporting add-on like GeometryGym or VisualARQ/Lands Design).
odv.hu | actively using: AC27-29 INT/HUN - multiple builds | Rhino6-8 latest build | macOS @ apple silicon / win10 x64
