2022-10-24 01:54 PM - edited 2022-10-24 01:55 PM
When I try to render with Internal engine I don't know how to insert a ground image. I can only insert a sky image as the picture.
Solved! Go to Solution.
2022-10-24 08:20 PM
It is not specifically a Sky image; it is simply a background image.
If you select the "Colors" option in the "Background" field then you can select a color for both the sky and the ground, but not images for both.
2022-10-27 12:26 PM
Hi Laszlo Nagy and thanks very much.
