2022-06-15 05:06 AM
Hi All,
When creating a detail or a worksheet from a floorplan, a dashed boundary line is placed at the marker range boundary.
I swear I had seen an option in the past to turn this off, but can't find it. Was I imagining this?
I can't even see what settings actually dictate the boundary line being drawn to be able preset it as a white or invisible linetype.
We are using worksheet to create room layouts (about 100-200), and the addition of that line is affecting the visual output of the drawing, so needs to be removed (refer snip below). We currently doing it manually, but it's a massive timesink as it keeps adding it everytime we rebuild from source.
I attempted to use a GO to hide it, but it seems GO's don't actually play properly with details or worksheets. 🤦♂️
Thanks,
Scott
2023-03-02 09:05 PM - edited 2023-03-02 09:36 PM
Hi Roland, thank you very much for your response. My clients are primarily using PC or Mac desktop.
UPDATE: OK, I have been playing around with the new Bimx update and have got the settings to be where they need to be:
Invert axis in settings
Turn on joystick
Hide Cursor
Thanks you for including the invert axis in settings , very much appreciated.
I would highly recommend just simply creating a Flythrough mode as in AC, for the sake of my clients sanity.
*original message deleted
Paul
