Render problem
Abdulqadir
Some objects disappeared from render
5 REPLIES 5
if you can elaborate more what’s happened, which apps and versions you use, which objects exactly disappeared that will help many diagnose your case and advise you in a right way.
AC 27 INT 5003/WIN 11
I have doing airport
So I've added road and airplane...... all the objects show in screen
But when I start rendering same objects are disappear
Are those objects from Archicad native library or imported from another app ( sketch up or 3DS ) ?
3d max (FXB)
So I think it’s the complexity of the objects imported from 3DS max, if other thing so we can ask help from @Rex Maximilian , @Emre Senoglu & @Francois_MCD I’m sure they can help in this visualization and FBX area.
