different room heights...
Eman
I have different room heights in each story. I mean in Ground Floor there are rooms with different heights and the same in Story 1 as the picture:
https://yadi.sk/i/HWN1rxaZO_yE2w
My problem is, that Door 1 is not showing in the Plan View of Story 1.
Eman / Draftsman
Works at an Architects Company using ArchiCad 21
Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.19 GHz, 8.00 GB, 64-bit operating system, x64-based processor
David Maudlin
Eman wrote:
"Symbolic cut" in the Floor Plan Display options is grey so I cannot click on it. All other options are black.
You will also need to change Show on Stories to Home Story Only. This means the Floor Plan Cut Plan will be ignored.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
4 REPLIES 4
Check that wall that contains door is set to "symbolic cut" in the Floor Plan Display options.
Eman
Hi kombibob
Eman / Draftsman
David Maudlin
David
Eman
David
Hi David, yes after changing Show on Stories to Home Story Only, now it is ok.
Thanks very much.
Eman / Draftsman
