We value your input!
3D Views don't appear in Version 24 Build 5000
After updating to build 5000, my title sheet with two 3D shaded vector views, updated, then disappeared. I drag them in again as new, still white. I create NEW 3D views, same thing. Has this happened to anyone else where 3D views in the layout disappeared since updating to build 5000 (AC24)?
Rex Maximilian, Honolulu, USA - www.rexmaximilian.com
ArchiCAD 27 (user since 3.4, 1991)
16" MacBook Pro; M1 Max (2021), 32GB RAM, 1 TB SSD, 32-Core GPU
Apple Vision Pro w/ BIMx
Creator of the Maximilian ArchiCAD Template System
I tried opening up Build 4018 and it reports that it will not open (I guess installing the 5000 build made this saved earlier ArchiCAD "not" open).
Minh Nguyen
Dear Rex,
Thank you very much for your report and I am very sorry about the issue!
We haven't received any similar report about this so far. I was unable to reproduce it either, so I'm wondering if you could share with us the file for a closer look? Please let me know if you need a secure place to upload the file also!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
