3d model settings
K-SAM
I'm a beginner and I'm struggling with 3d settings. My brick wall in 3d, pen lines are all over the drawing edges and it can't show mortar joints,bricks pattern or when I make a tiled roof it can't show the tile pattern. What might be the problem?
7 REPLIES 7
Hi @K-SAM,
If you illustrate your case with screenshots it gonna be easier for all here to help you.
AC 28 INT 5200/WIN 11
K-SAM
ā€ƒlike in this photo this is a brick wall. In 3d mode it only shows brick red colour but no brick pattern🧱. Same case on the roof in the model those are corrugated roofs but it can't show the corrugated pattern in 3d it only shows some white surface.
What is the problem?
Ok @K-SAM,
Simply go to View menu then 3D view options then 3D styles, if it’s set to Basic vectorial you can change it to (Simple shading vectorial or Simple shading) it gonna show your material pattern.
Currently it's in simple shading mode
But it's not showing
Check your (Simple shading) option settings, if 3D engine is set to Vectorial engine change into hardware acceleration option.
It only have vectorial engine
No open gl
If you provide your hardware specs, OS & Archicad version No. it’d be useful for advising you better.
