3d model settings
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2024-08-24 06:50 AM
I'm a beginner and I'm struggling with 3d settings. My brick wall in 3d, pen lines are all over the drawing edges and it can't show mortar joints,bricks pattern or when I make a tiled roof it can't show the tile pattern. What might be the problem?
- Labels:
3D Document
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-08-24 08:26 AM
Hi @K-SAM,
If you illustrate your case with screenshots it gonna be easier for all here to help you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-08-24 08:52 AM
 like in this photo this is a brick wall. In 3d mode it only shows brick red colour but no brick pattern🧱. Same case on the roof in the model those are corrugated roofs but it can't show the corrugated pattern in 3d it only shows some white surface.
What is the problem?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-08-24 09:00 AM
Ok @K-SAM,
Simply go to View menu then 3D view options then 3D styles, if it’s set to Basic vectorial you can change it to (Simple shading vectorial or Simple shading) it gonna show your material pattern.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-08-24 09:07 AM
Currently it's in simple shading mode
But it's not showing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-08-24 09:14 AM
Check your (Simple shading) option settings, if 3D engine is set to Vectorial engine change into hardware acceleration option.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-08-24 10:49 AM
It only have vectorial engine
No open gl
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-08-24 10:52 AM
If you provide your hardware specs, OS & Archicad version No. it’d be useful for advising you better.
