3d window contents to 2d lines
Darrin N
I have jumped a few versions to AC 20 and am trying to locate some features that have changed. I used to be able to save the contents of a 3d window to a 2D line file. This appears to no longer be an option? I wan to export the line work from a 3d view (for use in other graphics programs). How can this be done in AC 20?
Darrin Newnham
Arch. Tech., LEED AP
AC 6 - 20 - Windows 10
5 REPLIES 5
Aaron Bourgoin
Hey Darrin! try creating a 3D document from the 3D window and export that.
Think Like a Spec Writer
AC4.55 through 28 / USA AC27-6010 USA
Rhino 8 Mac
MacOS 15.2
Darrin N
There used to be a 2d lines file type available when doing a save as from a 3D document. That choice is gone I assume. I now have to use a DXF I guess? Or am I missing something?
What If i want to work with lines and hatches from a 3D document within Archicad? Can I explode the 3d document?
Thanks Aaron
Darrin Newnham
sinceV6
Hi.
Maybe you are looking for the old option:
In the 3D window, use the vectorial engine.
Make a marquee (with flat geometry method) around the part you want.
Hit "Ctrl-C" to copy the marquee content.
A dialog should pop up with several options.
You can then paste these in a worksheet.
Best regards.
Darrin N
That works great! Tough to find some of these features in the manual.
Thanks,
Darrin Newnham
Sebasti_n Cerda P_
To create a 2D line of a 3D what I have done is:
Create 3D view, then select all in the 3D view and paste it on a work sheet.
