AC 20 Door Window Label Problem in Elevation
Robby
I am working on a project that I started in AC 19 and am finishing in AC 20.
In AC 19, The Window and Door labels in Elevations were showing correctly their element ID such as W08, W09, etc.
In AC 20 the element ID is now prefaced with <no content defined> as shown in the illustration attached.
Sorry if obvious, but I can't seem to find where to change this.....
Rob Marelli
AC 27_5030
MacBook Pro (2023) M3 Max -48 Gb RAM - Sequoia 15.0
8 REPLIES 8
What happens if you change the ID Text parameter to "Compact Element ID" instead of "Full Element ID"? The Full Element ID shows the Master ID of the Hotlinked Module plus the Element ID.
Robby
Thank you for your response Lazlo-
so same thing with "Compact Element ID".....
Rob Marelli
AC 27_5030
Robby
I then tried with a fresh new file using AC 20 Residential Template.....
same thing....
Rob Marelli
AC 27_5030
David Maudlin
Rob:
I am seeing the same, the additional text reads "<no content defined>". When I open the library part and search the 2D Script, at Line 165 is the code:
if _sContentStringsHead[1][1] = "" then _sContentStringsHead[1][1] = `<no content defined>`
I can't easily tell where the bug is in the code, it would be up to the library part's author to fix this. I could not find any parameter changes that removes that text.
This Label is in the US Library, not the INT version.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Robby
Thank you David....
I guess not too many people use window markers on elevations.....
Rob Marelli
AC 27_5030
David Maudlin
Rob:
It looks like you could use the Identification and Property Label 20 to get what you need.
Katalin Borszeki
This issue has been known to us and we added it to our database to be corrected. Thanks for the report!!
Best, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
Robby
Thank you David - worked perfectly......
Also thank you Katalin for taking note.
Rob Marelli
AC 27_5030
