AC 21 Pen weight issue
Hi all,
Sorry for starting my membership here with a new topic, but I didn't find any similar questions or a solution for my problem.
Basically, I have a line drawing and I wanted to change the line weight from 0.13 to 0.05
Unfortunately, these lines on the layout sheet or in the published pdf appear as a light grey line. (every line below 0.13)
I used true line weight while I was editing these lines.
Is there any idea what I do wrong or any tip to solve it?
thank you,
Marton
2 Replies 2
Takis
Check that the drawing on Layout has the same Pen Set as the one you have on the view.
Takis.
Thank you Takis, it worked !
