alexliz
AC27 template - Classifications and Properties are empty
Am I mistaken thinking that if I do a File > New > New & Reset All then I should get the default AC27 template *with* the Archicad Classification v 2.0 15/3/2019 as well as the default Properties set?
Currently I get neither - both Classifications and Properties tables are empty.
Archicad 29.0.2 (3200) INT; macOS Sonoma
1 Solution
alexliz
UPDATE - I got it by expressly opening the AC27 template file. I went to File > Open > (switched the drop-down menu to 'Archicad Project Template' and navigated to the place in the Archicad 27 directory \Defaults\Archicad
Got the initial four sections showing in Plan View, and the Classifications and Properties were all there.
Hope this helps someone who has the same question.
Go to post
alexliz
