We are currently experiencing issues with our Graphisoft ID authentication service. Our team is working hard to restore service as quickly as possible. We apologise for any disruption.
Adding newline in property text values
DGSketcher
Legend
Is there a way to embed a carriage return/new line character in property values?
It would help make my notes and labels a lot more readable without having to resort to creating multiple property values.
DGSketcher
Legend
Thanks Barry. I can see what is going on. If you use the "Classification and Properties" label then as you say the use of \n is implemented, BUT if you create a label with autotext references to the same property values then the \n is displayed literally. And if \n is placed within an expression the \ is stripped.
Guess I will have to see if I can get the "C&P" label to do what I want. Unfortunately it doesn't allow text style changes to highlight or colour values unlike a simple autotext label.
4 REPLIES 4
\n works for general (text) properties and ID.
DGSketcher
Legend
Can you put that in context Barry?
If I enter a value directly/manually e.g. "My \n Newline" the displayed autotext result is literally the same.
If I do the same as a conditional value e.g. IFS (TEST, "My \n Newline", ...) the backslash is stripped from the text and "My n Newline" is displayed.
I don’t have ArchiCAD with me at the moment so I can’t show an image.
I put \n in the ID and in a general property of a wall where I could type any text.
I then added a property label to the wall showing both of these properties and they both had new lines created.
DGSketcher
Legend
