Adding to Labels
I Have downloaded Element Orientation Check from BIMcomponents.com:
Element%20Orientation%20Check
How do I upload it to the AC20 labels palette?
4 Replies 4
Just put it in one of your active libraries and you should be good to go!
Richard
AC26 (since AC6.0), Win10
Thanks Richard. I wonder if I have misstepped in terms of your advice. As per attached image, I added it with the Library Manager and used "Reload & Apply". The file is loaded but when I checked information it says the library contains ) library parts and nothing shows up in the Objects tool window (or Label tool).
Could you point me in the right direction? Thanks n advance.
Michael,
This is not an object, but a label. So with your label tool active, it should show up as one of the possible label types. If it doesn't, then maybe the .LCF file was not created correctly. But look at the label list carefully. It should be there.
Richard
Thanks Richard, there was something wrong with the download, it is showing up fine now.
