Amuny PDF
When I try to publish a PDF my paper size options are limited. I'm not able to choose 24x36. If there's a way to have the same options I had when I'm plotting? If it something with my plotter drivers or is AC10?
4 REPLIES 4
Djordje
Which PDF writer?
Why plotting?
When publoshing, are you Saving or Printing? Or Plotting?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I think I got your point. I was using the amuny PDF converter thru the plot command, but I think you suggest to create PDF thru the Organizer, right?
Djordje
I suggest you completely forget about plotting, especially in conjunction with PDF creation.
Print or save from the Publisher. Put everything in one top folder, click on the folder, set the print/save paramaters, done.
Djordje
HP Omen
Thank you very much Djordje.
