We value your input!
Another composite Wall Issue
If there's a way the end of a composite wall show the skin (as lateral sides). I need to cover a concrete core at the three sides of the wall.
If you will, notice that the wall tool now has a flyout. This flyout is the wall end tool...Keep in mind, that it is a new feature and won't totally behave the way you want. I haven't used it very often, but it should get you closer to Fig. 2. You may have to tweek your wall composite settings a little as well.
The flyout in the wall setting is not an option, so far I see no use for that.
