yesterday
Team,
I’m struggling to resolve a conflict in the appearance of a setting in my apartment tower model.
The issue is that one of the modules I’m displaying has three walls painted in a different blue tone compared to the other walls. There are no overwrites or renovation status differences between the walls.
In the original model, everything is correct, but the problem only occurs when I insert the module. In the elevation view, the walls appear to have a filter applied, making them look like they’re in the same blue tone as the plan.
I’ve tried various solutions, but I’m at a loss for why this is happening. If anyone has encountered a similar issue or can suggest a setting I should check, I’d greatly appreciate it.
I’ll keep trying to resolve the problem and post a solution when I find one. However, I’m running out of ideas.
21 hours ago
My first guess: Maybe you have Design Options. The Walls in question belong to one of the Design Options, the "Fade Environment" checkbox is checked, and a blue color is defined for their display in the Design Options Palette.
5 hours ago
Laszlo:
Thank you for your response. That sounds like the problem. It makes sense. So, I went to the DESIGN OPTION window and realized I had some options built without links. I deleted them just in case. I rebuilt the modules and updated them, but nothing changed.
