‎2016-03-23
02:59 PM
‎2023-05-19
03:54 PM
Gordana Radonic
‎2016-03-23 11:11 PM
‎2016-03-24 04:58 AM
jusauram wrote:Can you show something for me so i can share if i can help, i mean the working you did on the layout mentioned>
I have quite a lot of changes that need to be listed in my layout. I'd like to use the simple (not the detailed) version of revision history tool to avoid putting each change on its own row. In the simple version the max. number of rows per issue seems to be only two. Is there a way to change this? Now the text cuts in the middle of a change description because all the description can't fit in the first two rows...
Help!
EDIT: Actually it seems like there is a max. number of characters limitation. I changed the text size into a smaller one and now it cuts in the middle of the second line of the description field
‎2016-04-25 01:13 PM
‎2016-04-25 07:52 PM
GDL scripts may include paragraph definitions prior to the first reference to that paragraph name. The paragraph defined this way can be used only in the script in which it was defined and its subsequent second generation scripts. A paragraph is defined to be a sequence of an arbitrary number of strings (max 256 characters long each) with different attributes: style, pen and material (3D). If no attributes are specified inside the paragraph definition, actual (or default) attributes are used. The new lines included in a paragraph string (using the special character '\n') will automatically split the string into identical paragraphs, each containing one line. Paragraph definitions can be referenced by name in the TEXTBLOCK command. All length type parameters (firstline_indent, left_indent, right_indent, tab_position) meaning millimeters or meters depends on the fixed_height parameter of the TEXTBLOCK definition.The important sentence is in bold: each string within a paragraph can only be a maximum of 256 characters long.
‎2016-04-26 12:14 PM
‎2016-04-28 04:25 PM
‎2016-07-19 11:32 AM
