Archicad 21 does not display lines consistently when zoomed in and out
I noticed that Archicad 21 does not display lines of equal thickness correctly, when zoomed in and out.
Archicad 19 does on my computer.
I am on Windows 7 Pro, and I understand that Archicad 21 was not tested on Windows 7. I am just wondering if anyone else has experienced this?
Is there anything I can do to rectify this problem?
Thanks.
Sorry, I have found the answer myself.
(Options > Work Environment > Advanced Redraw Options)
Check 2D Drawing Antialiasing
Thank you for posting back the solution. It may prove useful in the future for other users as well.
