Archicad 22 Demo - Automatic Dimensioning
There is some issue with Exterior Dimensioning!
All Dimensions are different(overall)!
It's my fault or the program;
Regards
Billy!
Curious.
I will report this to GRAPHISOFT for investigation.
Csaba Kezer
Hi vakar,
Thanks for reporting this! It seems indeed when you use the Core Faces option in the Automatic Dimensioning, then sometimes ARCHICAD snaps to the skin next to the core skin, therefore showing a higher dimension value than it's supposed to. We'll be investigating this issue further and try to come up with a solution soon. Until then, you can Dimension your walls manually, or use the 3rd option (Dimension Structures) when you want to automatically dimension the Core structure of your Composite Walls. Best regards,
Csaba
Csaba Kézér
Director, Global Customer Support
