2020-11-04
04:59 PM
2023-05-19
10:06 PM
Gordana Radonic
Solved! Go to Solution.
2020-11-05 12:05 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-11-04 05:32 PM
2020-11-05 08:14 AM
2020-11-05 12:05 PM
Minh Nguyen
GRAPHISOFT
2020-11-05 12:20 PM
mnguyen wrote:Yes! That was the problem! I detached the XREF and the problem was solved
Hi Achille,
Thank you very much for the question and I am very sorry about the issue!
Currently, with AC24 we are having an issue with DWG export if the project contains a "missing" XREF on macOS. The detail is unclear to me, but on macOS, due to the missing location, the DWG process will fail. On Windows, the missing XREF's location is ignored, therefore it is not an issue.
Because of this, I would like to check whether any XREF is missing from your project file.
Regarding the failed repair process, I'm not quite sure what happened here. Without Open & Repair, is there any other error when you open the file?
Best regards,
Minh
2020-11-05 12:21 PM
Minh Nguyen
GRAPHISOFT
