Mykee
Archicad 26 - 2D elements and lines not displaying correctly on 4K screen
Archicad 26 seems to display 2D element differently than 25 as I notice more distortions and thickening to hair lines (no line weight drafting). I usually use these in 25 to identify sloppy drafting. However when zooming in fully to these areas the elements are correctly drafted! I also notice straight lines 'stepping' across 1 - 2 pixels on elements like stairs (image attached) but also disappear when zoomed in. These distortions are a total waste of my time as I spend more time zooming in finding phantom drafting errors than I do drafting!
Archicad 26 Int Build 5002 FULL, PC 4K dual screens
5 Replies 5
Marc H
Could it be that your AC26 install is using the default GPU instead of your dedicated GPU?  Also, is your True Line Weight button on?
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC28 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
Mykee
Thanks Mark,
I stumbled on this thread with the solution. Apparently the new 2D rendering API has issues with windows based display scaling (mine is at 150%). so I reverted to the legacy rendering.api. fixed it for me. I'll just wait till the hot fix this.................
https://community.graphisoft.com/t5/Installation-update/Archicad-26-and-DPI-issue-on-4K-monitors-und...
Lingwisyer
Guru
The issue is that at 150% scaling, your 1 pixel becomes 1.5 pixels, which is not possible to display... To not have this sort of issue you would need to go up to 200%. @Mykee, when you say "this thread" it would be helpful if you linked said thread.
Ling.
Mykee
Thanks ling!,
The 150% comment makes sense, I'll try 200% but i fear it might make everything too big.
Marc's reply updated to include link to other thread
Lingwisyer
Guru
If need be, it is possible to have an application ignore Display Scaling. This can be set within the program's compatibility settings. In doing this you can keep your desired scaling while disabling it for specific programs in which it causes issues in.
Ling.
