Too Long
Archicad 26 Project Location
The option to select a predefined city via the "globe" button in Project Location has been removed in 26.
Other than inputting the actual coordinates how else can I add the location of the building?
AC26 AUS Full
3 Replies 3
Coordinates only now.  Just use any map app to get them.
https://help.graphisoft.com/AC/26/INT/#t=_AC26_Help%2F005_NewFeatures%2F005_NewFeatures-25.htm&rhsea...
Eduardo Rolon
  • Reported as a Bug during the Beta.
  • IIRC GS reported it back that using Google Maps is now a NEW feature of 26.
  • Argued back that depending on information from another company is a bad idea specially when you already had that info for the last 20+ years.
  • Bug moved to "we will check…"
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Too Long
Thanks.
Pretty poor form really. It worked fine previously and now we need to manually enter coordinates? Where is the efficiency there?
AC26 AUS Full
