jevht
Archicad 27 & 28 Sheet Index Fatal Bug
If you divide sheet index into two or more drawings inside a layout. It will not load and messed up the drawing update system also to the project file. The project will be corrupted. Seems replicable.
Happened to both archicad 27 and 28.
Operating system used: Windows newest
5 Replies 5
Does this happen with one project in both Archicad 27 and 28, or does it happen with multiple different projects?
I am trying to see if this problem is file-specific or project-specific.
jevht
I have tried to recrerate the problem by using Archicad's default template, also tried to use other projects as well. It seems it is not project/file-specific. Both the archicad 27 and archicad 28 default template showed same problems
OK, thanks for the additional info.
I will report this to GS HQ.
jevht
I can confirm that the issue persist in Archicad 29. Also in new Archicad 28.3 update.
jevht
It's suprising that a bug as fatal as this still not being looked at by Graphisoft 😞 Is AI more important now than basic functionality of the software? I wonder if Archicad will survive the next 5-10 years of being like this.
