Automatic Dimensioning tool
I'm having trouble getting the automatic dimensioning tool tool to work.
I select all the walls I want to dimension, then select the dimension tool, and when I try to select automatic dimension it is grayed out (not an option).
I've tried this several different ways, and followed the steps in the ref. guide, but so far not much luck. It has worked once or twice, but I have not been able to figure out what I was doing differently.
5 REPLIES 5
__archiben
that's your problem: you don't go near the dimension tool except to initially define its parameters.
• open dimension tool settings, set up fonts, pens, lines, sizes, etc.
• select walls you want to auto-dimension
• from your menu (these are archicad 10): Document>Document Extras>Automatic Dimensioning> and choose the type dimension you want: exterior or interior.
• use the resulting dialogue to set up what and where the dimensions will be.
HTH
~/archiben
b e n _ f r o s t
Stress Co_
It may also help to turn on the "Statusbar". It'll describe the next step.
Window> Palettes> Statusbar
Marc Corney, Architect
Red Canoe Architecture, P. A.
I m having the same trouble, am using AC10 10 but have no Document on my menu bar. How to put it there?
BR
F
David Maudlin
Broker:
Try changing the Command Layout Scheme in your Work Environment, to see if there is one with this menu scheme, or you can add the Exterior Dimensioning ... and Interior Dimensioning ... menu commands to your current Work Environment.
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Hi
Thanks for your reply. I have in fact found the answer by changing the profile to Layout. There it is.
Best regards
Fred Wright, Architect
