‎2006-11-16
06:01 PM
‎2023-05-30
03:23 PM
Rubia Torres
‎2006-11-17 04:08 AM
Dovetail wrote:that's your problem: you don't go near the dimension tool except to initially define its parameters.
I'm having trouble getting the automatic dimensioning tool tool to work.
I select all the walls I want to dimension, then select the dimension tool, and when I try to select automatic dimension it is grayed out (not an option).
‎2006-11-17 05:31 PM
~/archiben wrote:It may also help to turn on the "Statusbar". It'll describe the next step.
• use the resulting dialogue to set up what and where the dimensions will be.
‎2007-02-23 05:52 PM
‎2007-02-24 02:30 PM
‎2007-02-24 02:44 PM
