Automatic print/plot information on drawings
Kristen
I am wondering if there is anyone out there who has a good solution for publishing print/plot information automatically on drawings.
I am looking for something that gives me the file name with the path, the name of the layout that is printed, the name or initials of the person printing, and the date and time of printing. All this can be achieved with the header/footer option that exists in ArchiCAD but i am not satisfied with this alternative because it places the text outside the printable area of the drawing.
Ideally I would like the text to be standing along the left hand side of the drawing just outside the drawing frame.
I have an object which is part of the way there and works just fine if I print directly from the screen but if it is placed in the layout, then it must be rebuilt for every file that is printed and that just doesn't work.
I'd like to know how others have solved this issue
Kristen Broberg
AC 23 SWE Full on Windows 10 Pro
HP Zbook 15 G6 32GB
i7-9850H 2,6GHz
Quadro M2200 2GB
www.liljewall.se
5 REPLIES 5
Thomas Holm
Use the Text tool, make a text field where you want it, right-click, select Autotext... See figure
You can insert any Project Info (like initials) along with system info, file path etc. If I do this on a Master layout, I get what I want automatically on any of its children.
When you Print, there is also the header/Footer checkbox in the Print Dialog which has various options you can set to appear on the printed output.
Kristen
Thanks Thomas for the autotext tip, I did not think of that.
Laszlo, I had tried the header/footer option in the Print dialogue but do not like this because I cannot affects it's placement. It always ends up outside the printable area if we are printing on an A4/A3 copier.
Kristen Broberg
HP Zbook 15 G6 32GB
i7-9850H 2,6GHz
Quadro M2200 2GB
www.liljewall.se
Then you should go with Thomas' suggestion as it gives you more freedom and options.
Kristen
The autotext works perfectly...it does exactly what I want! Thanks for you help.
Kristen Broberg
HP Zbook 15 G6 32GB
i7-9850H 2,6GHz
Quadro M2200 2GB
www.liljewall.se
