2021-12-02 03:22 PM
Just curious if Archicad 25 would finally have this long needed feature? Automatic alignment of 3D texture to 2D fill of that same surface material? I know we can align in 3D window but it's such an unnecessary work. There's gotta be a way to automate this
2021-12-02 04:38 PM
Hy,
Like this for a long time 😏
2021-12-02 08:13 PM
This is only setting the 2D fill in the plan, it doesn't affect the 3D texture.
2021-12-02 08:18 PM - edited 2021-12-03 09:18 AM
Try the texture follow the orientation
2021-12-03 11:57 AM
You can try to create a 3d-document out of the flooring plan. in the settings of the created 3d document you can enable the vectores and they change as in 3d.
2021-12-03 02:00 PM
You misunderstood my original post. The problem is: setting the 2D fill origin doesn't affect the 3D texture origin.
I'm assuming this still isn't available in Archicad. Setting the textures in 3D is double unnecessary work.
2021-12-03 03:35 PM
2021-12-03 04:06 PM
I just read on the Archi-cadlink forum that this function has disappeared since Archicad 23.
The managers of graphisoft may be able to explain to us how an essential function was removed 😡
2021-12-03 06:15 PM
It's been two years and two versions since this bug was introduced.
Graphisoft are you listening?
2022-10-04 04:48 PM
@GRAPHISOFT any news regarding this bug? Crazy that such a basic thing is not working properly... especially since it has been working before...
