Automatically align 3D texture to 2D fill?
amgam
Just curious if Archicad 25 would finally have this long needed feature? Automatic alignment of 3D texture to 2D fill of that same surface material? I know we can align in 3D window but it's such an unnecessary work. There's gotta be a way to automate this
ArchiCAD 25 FRA 3011 + TwinMotion 2021.1.4
iMac Retina 27 2020 3,8 GHz Intel Core i7 8 cœurs
64 Go 2667 MHz DDR4
AMD Radeon Pro 5700 XT 16 Go
9 REPLIES 9
Yves
Hy,
Like this for a long time šŸ˜
ā€ƒ
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
This is only setting the 2D fill in the plan, it doesn't affect the 3D texture.
64 Go 2667 MHz DDR4
Try the texture follow the orientation
ā€ƒ
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
_nique
You can try to create a 3d-document out of the flooring plan. in the settings of the created 3d document you can enable the vectores and they change as in 3d.
You misunderstood my original post. The problem is: setting the 2D fill origin doesn't affect the 3D texture origin.
I'm assuming this still isn't available in Archicad. Setting the textures in 3D is double unnecessary work.
64 Go 2667 MHz DDR4
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
I just read on the Archi-cadlink forum that this function has disappeared since Archicad 23.
The managers of graphisoft may be able to explain to us how an essential function was removed šŸ˜”
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
It's been two years and two versions since this bug was introduced.
Graphisoft are you listening?
https://community.graphisoft.com/t5/Design-forum/BUG-in-23-Slab-and-Roof-Surface-Textures-in-3D-do-n...
AC user since 8.1
@GRAPHISOFT  any news regarding this bug? Crazy that such a basic thing is not working properly... especially since it has been working before...
