Autosave folder did not autosaved my work
I had a crash during publishing and wanted to work on the saved file that I knew that with the autosave option it is stored in the autosave folder.
I went over the autosave folder looking for the file and with my surprise that the autosaved file doesn't exists!
I checked the work enviroment profile under data safety and double checked where the autosave files were stored, but the file doesn't exists.
Does nybody knows what happened?????
Thanks
10 REPLIES 10
Correct, that's how it works.
If you do not open it then, ArchiCAD considers you will not need it at all and deletes it.
