2023-08-31 10:27 AM
Hello, I have a problem. When starting Archicad 25, a "caution" box appears with the words "cannot create temporary documents". And after a few seconds, the program closes itself. It does not create a new file either. I tried deleting all the files that appear in the first page and the box remains. In the folder Graphisoft, there is no file "autosave-25". Could you please help?
2023-08-31 10:39 AM - edited 2023-08-31 10:39 AM
Does your user profile have full read/write access to all of the folders it should on your local drive?
Sounds like a permission problem to me.
What operating system are you using?
2023-08-31 10:42 AM
Hello!
I am using Windows 10, if this is what you mean.
My archicad licence is for students. Till yesterday, I was using it but today this problem appeared.
Thank you for your reply!
2023-08-31 10:46 AM - edited 2023-08-31 10:47 AM
You have disc space? Temp folder space? Run a disc cleanup, or what ever the eq. is on Mac?
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Self-taught, bend it till it breaks | Creating a Thread |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
2023-08-31 10:52 AM
If it was working before, then the problem isprobably not access permissions.
More likely a lack of hard drive space as Ling has suggested.
2023-08-31 11:07 AM
Free disc space: 30GB and I just deleted all the files in temporary folder. I tried to open Archicad again but the message remains.
Thank you!
2023-08-31 11:13 AM
Completely re-boot your machine.
That may clear the problem.
2025-01-30 09:57 PM
I am having this issue on 01.03.25. in Archicad-26-USA-Update-7004 . I have deleted all AutoSaves in the startup of ArchiCAD, as some have suggested. I can't find the actual AutoSaves in the Graphisoft Folder. Does anyone know where this is located? I have downloaded a new ArchiCAD 26 and restarted my computer. Running out of options.
2025-01-30 11:18 PM
Solved. For PC users ArchiCAD26 (or other versions).
Make sure you are NOT heading to System C > Program Files > Graphisoft > ArchiCAD26 (or other version). Make sure you are going to System C > Users > Graphisoft. Otherwise you will not be able to see all the AutoSaves, which you need to delete here. That should work. Hope that helps someone.
2025-01-31 01:37 AM
For an example image of the location (on Windows machine), see my post here.
I would merge the two posts, but I find that can be confusing when both have been replied to.
