Scott Bulmer
Autotext Label Mesh Elevation Nodes Selected in a 3D Document Window
Labeling node elevations in plan view works nicely using the level dimension tool and gravitate to mesh on. Is it possible to do something similar in the 3D Document window? Thank you, Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
1 Reply 1
Podolsky
Ace
yes, it's possible. Just in 3D document you need to use dimension tool and switch it to elevation dimension, when in floor plan you are using level dimension tool (unavailable in 3D document).
