Autotext in Story Settings
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2014-05-26
03:05 AM
‎2023-05-19
03:56 PM
Gordana Radonic
‎2014-05-26
03:05 AM
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-05-28 12:35 AM
‎2014-05-28
12:35 AM
Also on a not completely unrelated matter. Has anyone had any success using the import xml feature associated with the Project Info window?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-05-28 11:24 AM
‎2014-05-28
11:24 AM
herb606 wrote:Yes, it works wit no problem when I import .xml file that containes "Project Info" data from another Project.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-05-29 03:04 AM
‎2014-05-29
03:04 AM
ah...OK, yes I agree importing like for like project info xml files is not an issue, I should have explained my issue better.
I am exporting a Profect Info xml file for editing in order to customise it (because for some reason it isn't entirely customisable by default), and consequently having no success importing it back in.
I am assuming that customised Project Info xml files can't be imported.
I am also assuming now, due to no responses, that I am not able to code autotext into the story settings text input fields.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-05-29 03:23 AM
‎2014-05-29
03:23 AM
You can add custom entries to the Project Info and in 18 you should have more options. As for the Autotexts on elevations I use this.
http://www.masterscript.nl/home/33-elevation-dimension.html
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
AC28 US/INT -> AC08
another Moderator
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2014-05-29 06:04 AM
‎2014-05-29
06:04 AM
Yes I am aware you can 'add' custom fields, however there are a number of 'fixed' fields which I have been attempting to modify by messing with the xml code. Importing modified xml code is the issue I am seeking an answer to.
I have managed to solve my original question on using autotext code in the story settings input fields. This is possible providing your code is entered correctly, which I must not have done originally - apologies. (All capitals and no spaces)
e.g. <PROJECTNAME>, or <CUSTOM1>
