Autotext line breaks
As queried in this wish is there a way of adding a hard return to a line of autotext, specifically on a Mac (I remember doing it in Windows). A good example if for a Layout title.
We have tried typing the required text in a normal text field and copy/paste into layout name, but this does not work.
A search revealed that wish linked above, hence the double post.
Cheers
17 REPLIES 17
Subsets suggestion sort of worked, but had it's own problems (like, what if a Section drawing was amongst the plans), but it has some merit.
Surely we're not the only (Mac using?) people in the world of Architecture that strike this problem? Can you still put a return in Windows Layout names? I vaguely remember losing this ability in later releases.
Thanks for your continued efforts, guys.
Link
I've met many users over the years that have encountered this problem on both platforms. No one has come up with a workaround that is flexible and reliable. Of course they shouldn't need to come up with a workaround, because Graphisoft should take the multiple bug reports and do something about it.
Who knows, maybe Laci can jump on his bike again and whisper a request in the boys ears?
Link.
owen
Our subsets usually only contain drawings of a particular orientation - such as GA Plans, GA Sections, Detail Plans, etc - so we haven't really run into this problem. Everyone has their own way of organizing drawings though so i guess this isn't going to work for all.
Still using GDL is probably the only way to do it .. i think you can use pretty much any character in a string to act as a line break if you want stick with using just the Layout Name for your title
s2art wrote:
owen wrote:
(ive just been to a Bjork concert so im not really in an AC mindspace right now)
I can understand that.
Fantastic concert - setting on the forecourt terrace of the Sydney Opera House. It sure must be interesting inside her head .. a friend described it as 'a mouse and a rattlesnake in a knife fight'
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
Link.
Well, I can certainly tell them about it, and I will do so.
Unfortunately, that's all I can do for now.
Djordje
You can sorta line break it, by resizing the text bounding box.
But you can't exactly control where the break is, so it is an 80% solution.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Vasileios S_
Any luck on after 13 years on this post?
You cannot build a line.
Exactly what are you trying to split?
If it is one autotext value, then no you can't split it unless you stretch the text box.
If it is multiple autotext values or text and auto text, just ENTER to get a new line.
Is line break possible?
I want to down to the next line to "구조평면도".
AC27 on window 11
