svpribyl
BIMx Project is saving sheet views and one camera view, but no Gallery Views
If I understand correctly, placing cameras in the 3d view prior story saving as a BIMx file should save the views as "gallery" elements. They are not being saved in my file. What would you suggest?
Steve Pribyl
MAC OS Sequoia 15.5
ArchiCAD 28
3 Replies 3
svpribyl
Should I post this under a different category?
Steve Pribyl
MAC OS Sequoia 15.5
ArchiCAD 28
I moved your post as it really does not have anything to do with setup and licensing.
I don't have an answer for you without doing some investigation myself - I don't use BIMx very much.
My understanding is that placing cameras will create gallery items.
I am not sure if you need to save those camera views in the publisher set.
It is probably not to simply create the views.
You need to tell BIMx that you want them included.
You could also try emailing ... [email protected]
I just found this, maybe it will help.
https://community.graphisoft.com/t5/Visualize-articles/How-to-add-camera-views-to-the-BIMx-Hyper-mod...
There is also a new desktop and web version.
https://community.graphisoft.com/t5/Visualize-articles/Next-generation-BIMx-Web-and-Desktop-Viewers/...
