4hotshoes
Camera Tool Bug: when sharing a project from Solo to Teamwork
This is not a real bad bug, but it is annoying in that I have purposely set up my template to work logically. And the Camera tool is not playing nice. Or maybe it is Teamwork.
I have a list of cameras set up in our template in a specific order so that “00” has cameras turned off. This is so that I do not see cameras on the plan view. However, when I share the solo project to Teamwork, the logical order of the camera sets are altered. See the screen shots below.
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
I think I would call that a bug/oversight rather than a wish?  The Camera tool has not been improved/modified, as far as I know, in 24 or more years, so I almost wonder if the developers just didn't pay attention to it in the case of TeamWork conversion.  Regardless of speculation, you should report this is a defect to your local technical support so that it can be forwarded to the developers.
