Fab Rodriguez
PhotoRendering Settings Dialogue Window Not Showing
Hi All,
My PhotoRendering Settings Window is either not working or it is somewhere not visible when selecting it.
I do switch from using monitors in the office to working just using my laptop screen regularly. Could this be the problem?
Has anyone had this issue?
1 Solution
Yes it could well be on a second screen.
You could try applying just a default Workplace Scheme in the Work Environment.
Do not apply the entire default Work Environment if you have your own keyboard shortcuts or custom menus - you will lose those.
Applying just the Workplace Scheme will only affect the position of palettes and toolbars.
Or plug in your other monitors to find it.
Go to post
Fab Rodriguez
Thanks! That seems to have worked.
