‎2023-05-08 05:59 AM
Hi All,
My PhotoRendering Settings Window is either not working or it is somewhere not visible when selecting it.
I do switch from using monitors in the office to working just using my laptop screen regularly. Could this be the problem?
Has anyone had this issue?
Solved! Go to Solution.
‎2023-05-08 07:17 AM - last edited on ‎2023-05-09 12:34 AM by Karl Ottenstein
Yes it could well be on a second screen.
You could try applying just a default Workplace Scheme in the Work Environment.
Do not apply the entire default Work Environment if you have your own keyboard shortcuts or custom menus - you will lose those.
Applying just the Workplace Scheme will only affect the position of palettes and toolbars.
Or plug in your other monitors to find it.
‎2023-05-08 08:33 AM
Thanks! That seems to have worked.
