Back referencing a section marker in a detail
does anyone know if there is a way to put a Section source marker into a detail so it can be back referenced?
thanks
4 REPLIES 4
I don't know if it can be done as standard option, but
I did make a "back" reference of a detail back to the section cut on my last set of plans, because I thought that it was an appropriate thing to do in that
particular instance.
However, I got it RED lined by a very experienced and picky plan checker who got confused about it. So go figure?
Stress Co_
Not sure if I understand the question,
but if you mean you want to place a section marker that's linked to a view or drawing.... then open the Section Marker settings and choose "place linked marker" (then select which drawing/viewpoint you want it referenced to).
Marc Corney, Architect
Red Canoe Architecture, P. A.
The section marker that is linked to a view or drawing can't be back referenced to. At least I haven't found a way of doing it.
The back reference only seems to work from the detail drawing back to its source marker on the section.
Erika Epstein
Like Marc I have no problem back-referencing section markers and changing the reference. Are we misunderstanding what you ar trying to achieve?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
