Read more
Bad Dimension Chain
Why don't these two dimension chains add up?
There are no fractions in it, the overall dimension should not have any either.
Yes, I have checked the obvious settings. All are set to max. (1/64")
Any ideas?
4 REPLIES 4
Link
Steve,
Can you upload a file containing this dimension chain and the associated building elements?
Link.
this is it. I deleted the windows and doors to get the file small enough to post.
Link
And you said you checked all the obvious settings!
Seriously, did you set your Dimension preferences to 1/64"? This is different than your Working Units.
Link.
