Learn more
mukster
Beam Labeling Problems
I am putting in a series of roof beams and labeling them. The labels show up fine when I'm on the view map, but when I go to the layout book, the beams show up but the labels don't. Any idea why this might be?
2 Replies 2
Check to see if the pen set is correct for the layout drawing in question.
You might be using a pen for the label that is not included in the drawings pen set.
Or could it be that the drawing is set to manual update and just hasn't updated yet?
Everything can be updating fine on my layouts, then bam, one won't update no matter what.
If it is one of those rare stubborn drawing to get to update, drag new copy of the saved view and at least for now, frustration over.
ps
You might want to consider adding a machine/software/version to your profile.
Laura Yanoviak
Prior to AC12 there was a bug with Labels and Display Order -- even though set correctly in the View, sometime the Labels were obscured in the Drawing on the Layout.
As far as Drawings that won't update -- wouldn't it be easier to Relink the Drawing to the source View instead of re-placing the Drawing?
