Gerry Leonor
Building Material IDs in Labels
A bit of a complicated question for the Hive Mind:
is there a way i can grab the Building Material ID to be called up in a Label?
we've been able to use the same methodology by calling up the Codes in the Surfaces using a Split command in the Properties.
We'd like to use the Property Manager in a similar way to call up the Building Material ID. an added complexity to this is that we'd like to use it in Composite Walls.
https://discord.gg/XGHjyvutt8
10 Replies 10
artecon
Hi Kevin,
Im willing to make this skin list label, but the label that call up only outside/inside skins material ids? Is it possible somehow? Im very noob at programming, everything i tried didnt work.
So, instead of listing all building materials id in label, and instead of listing only one (for example last outside skin material), i want to list all just outside skins materials, or ALL just inside skins materials.
Thank you a lot
