2020-01-2312:16 AM - last edited on 2023-05-3009:56 AM by Rubia Torres
2020-01-2312:16 AM
I am helping out a co-worker and this file seems to have different Settings. I'm finding myself changing displays and whatnot.
Anyways, I am stuck on Building Section appearances. Reference Image Attached. The Roof and Slab objects do not visually combine. I would like these to read as combined objects (no lines at intersections). So it would be a grey fill instead. Black outline. Does anyone know what Setting I need to adjust?
I appreciate your time and help. Kind Regards, Jakub
I see on the image, that earth and concrete fills present. That means possible problem might be that elements have different building materials with the same cut look. Maybe that cause these lines.
Try to make set of graphical override, that changing cut fill to grey for all elements, but exclude foundation and landscape.
