dhnguyen
Building Surface settings
I wanted to have a lap siding building surface material with 12" increment, ArchiCAD doesn't have that default material so I created a new "surface" where I chose the 12 vectorial hatching line. However, I can't get the horizontal lines to show up on my surface material, please see attached for the image.
Thanks.
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
9 Replies 9
Guru
That will only show in 3D when using the vectorial engine or when you render with vector hatching enabled. You cannot use the Siding material?
Ling.
David Maudlin
DNguyen:
If you want the siding to show when the 3D Window is set to OpenGL, you will need to add a Texture to the Surface settings. From your screen shot, take a look at the Roof Surface you are using as an example.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
dhnguyen
The default building materials only give me wood siding options with 6" exposure. I want a custom one where I can make it 1ft instead. If i try to create a new building material, there is no option for me to change 6" to 1ft.
Ling.
DNguyen
ArchiCAD 18- 25
dhnguyen
Thanks for your response, it sounds like i need to create a texture with the specific 1ft increment for it to show up
David wrote:
DNguyen:
David
DNguyen
ArchiCAD 18- 25
David Maudlin
You may not need to create a new texture, just use the Size inputs in the Texture section of the Surfaces dialog box to resize the texture. So if the current texture is set to 6", increase it to 1'-0".
David
Guru
Doubling the vertical size will also increase the seam size which may not be desirable. It should be a relatively easy photoshop job to erase every second seam.
Ling.
dhnguyen
Could you please show me a screen shot of where this option is? Is it available in ArchiCAD 18?
David
DNguyen
ArchiCAD 18- 25
David
It is the bottom section of the surfaces dialogue that you showed in your first post.
dhnguyen
I see, I got it now, thank you!
DNguyen
ArchiCAD 18- 25
