Can not save to DWG?
For some reason, I am not getting the option to save or publish to DWG? Any thoughts on what I may be missing?
10 Replies 10
TomWaltz wrote:
When you click About Archicad, you get a graphic with a small "build number" on it.
That number tells you exactly which version of Archicad you are using. The latest for Archicad 10 is build 1183.
Sometimes if you deal directly with Tech Support, you may get a different build than the public has.
If you really want to know more:
http://en.wikipedia.org/wiki/Software_build
Now this what i call a teacher!!!
THANX
