Can't print a "sketch" rendering engine
Just started using AC14 and the first bug is that I can't print an image that was rendered using the Sketch engine. Lightworks and the internal engine print just fine.
I can save the rendering as a jpeg and then print it, but I can't directly just print it, or print to PDF.
We use a Savin C2824 printer, all our computers are Mac Pros w/ intel chip running Snow Leopard.
Any ideas? Some kind of driver needed????
3 Replies 3
I can confirm this bug in 14 with Snow Leopard. Works fine with 12. Just clicking the "Preview" button in the OS X print dialog is sufficient to show the bug in 14 and the proper function in prior versions.
Please report to tech support. Looks like you've found the workaround (save image to print, or place view on layout)
Karl
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
I can confirm this bug in ArchiCAD 14. However, a fix for this is coming soon!
Greg
Gergely Kmethy
VP, Customer Success, Graphisoft
Yes- I contacted Graphisoft tech support and they have confirmed that this is taken care of in the first hot fix that comes out in about a week.
