‎2004-08-30
02:16 AM
‎2025-02-10
04:17 PM
Aruzhan Ilaikova
‎2004-08-30 02:37 AM
‎2004-08-30 03:07 AM
"Matthew Lohden" wrote:
If you want to change the scale in PlotMaker just look in the "Attribute Update Rules" right below "Attributes" in the settings dialog.[/quote
I did just that and the scale option is still greyed out.
[quote="But...
It is better to change the settings in the ArchiCAD views and update the drawings. There are a lot of library parts that are scale sensitive and won't respond correctly to scale changes in ArchiCAD.[/quote
....and I have done that also without the results I'm not looking for, for example, I would change the scale in AC views, redefine, open up PM and then update that same layout and the new drawing scale from AC would not carry over to PM. I have also tried numerous times to reset the scale in AC viewsets, then redefine, open PM and import a new drawing from viewsets and the scale still imports with the wrong scale. The only way that the drawing is imported with the correct scale is if I first save that view as a .pmk.
By the way Matthew, thanks for the quick reply.
Jim
‎2004-08-31 02:52 AM
‎2004-08-31 06:45 AM
‎2004-08-31 05:28 PM
‎2004-09-01 04:38 PM
But I still don't understand why that when I import viewsets it does not import with the scale that was draw and saved in within AC, even after redefining the view. I guess I'll never know.If there are several view sets that are similar it is easy to chose the wrong view set in plotmaker. This process has worked seamlessly for me.
